granada disc setup
Fst Blk
I believe I lucked upon a granada disc brake setup. It was in the 69 FB that I picked up. So, that makes this setup really inexpensive :whis :yah
Anyhow, I don't know much about them. Does the bolts that tie the caliper bracket to the spindle require a castle nut and cotter or will a simple nut and bolt setup suffice. Does it look like I'm missing anything?
Oh, and the best part of this was that it was just laying in the car. There is still a disc setup on the car :thum It's missing some pieces but...
Bill
A
Anonymous
Guest
Don't forget to buy the right tie rod ends (Mustangs notta fit).
Fst Blk
Yeah, I spoke with John about the tierods. I'm buying a complete setup from him, so he get me the right pieces.
Bill
Ponyman66
Yak, yak, yak
"Larry G" said:
I think the calipers are bolted to the brackets and wired together.
Not with the Granada style calipers. They are "floating" calipers. The four piston Kelsey-Hayes calipers are a "fixed" style and are indeed bolted though.
Opentracker
I believe the caliper bracket is threaded and is held on by two course thread bolts that pass through the spindle. There are no nuts or safety wires.
Larry G
The pictures that Bill posted are of 69/70 disc brake brackets and calipers, the caliper bracket is bolted and safety wired to the spindle.
Here's a couple of picture's from my disassembly photo's.
Fst Blk
That doesn't sound good.
This is what the setup looks like. Will they marry and be happy???
Bill
Opentracker
It looks like you have both. This one looks like a Mustang disc brake.
This one looks like a Granada
Are those two different spindle and caliper set up's ? - They look different in the photos
Fst Blk
The one attached to the car is probably a factory 69 setup. The setup all together on the ground is what I dug out of the car. It looks like it is all the same. I know the caliper brackets/calipers are the same. They both have d5 castings on the brackets. The spindles... well I'm not sure if they are the same. Is there a way to tell for sure?
Bill
Fst Blk
I was wrong, I just went and looked. The spindles have the d5 castings, so they are the same. The brackets look identical.
Bill
tarafied1
yes, you have Granada spindles and calipers on the ground. You just appear to be missing the bolts that hold the brackets to the spindles.
here is a few shots of just the bracket and spindle assembled
these are the gizmo's that allow the caliper to float (which it looks like you have)
Ponyman66
Yak, yak, yak
Sorry Larry, I was just responding to your post where you stated the caliper was bolted to the bracket and wired. Your are indeed correct in your second post that the 69/70 caliper bracket is bolted and safety wired. I have never seen the Granada set up safety wired (though it doesn't mean is was never done at some point).
BTW Bill, if you don't like the threaded brake lines for the calipers on the Granada set up, you can use '79 Jeep CJ7 V8 calipers and the long lines (they come in different lengths). You get banjo fittings at the calipers instead of the threaded fitting. Believe it or not, the calipers ARE Ford calipers. Some rebuilt units will even have a Ford oval cast into them! You can pick up a professional grade Raybestos rebuild already loaded with semi metallic pads from Rock Auto for $45 ea ($10 of that is core charge)!
Fst Blk
79 CJ7's huh, good to know. What length line would you use?
Bill
Ponyman66
Yak, yak, yak
I'll dig through my stuff this evening and get the part number. I got the numbers off of Rock Auto, then went down to a local parts store that had them in stock. This allowed to put hands on and check/measure to make sure they were the correct length. IIRC I then dug them up on Ebay for a price cheaper than anyone else's and bought them there!
I've got the Granada conversion for my '66 coupe. I did buy a set of spindles from CSRP though (since I was converting a car originally equipped with a 6cyl). These have the correct 65/66 steering geometry. They were also the most expensive pieces for me in the whole conversion. All of my other brake components (master cyl, calipers, rotors, pads and lines are all Raybestos), and I was able to locate them at rock bottom prices (yeah...I'm cheap! LOL). Heck, I got the pads (Raybestos PG grade semi metallics),for something like $7!! I found a rebate form for them AND bought them on sale!! I believe the total conversion (including new dust shields, hardware and Timken wheel bearings/seals), cost me right at $350.
Horseplay
I Don't Care. Do you?
Every merchants nightmare! I think we are all guilty of such. We're so bad.
Ponyman66
Yak, yak, yak
Although I am on a very tight budget and have to get the stuff for my project as inexpensive as I can, I actually buy a lot of parts from this particular place too. I didn't feel too bad about it (matter of fact I just bought some plugs for the car from them this past weekend....because they were on sale of course!).
Ponyman66
Yak, yak, yak
Jeff I haven't forgotten your question. I looked through some of my stuff for the lines, but at the time I couldn't find them. I have tons of parts for the car squirreled away awaiting installation. It's driving the wife crazy! I'll have more time to look tomorrow though. I will get you an answer!
