guruatbol
Always on vacation!
Maybe you should get John's gauges for your car????
Ask Pete...
Ask Pete...
"guruatbol" said:Maybe you should get John's gauges for your car????
Ask Pete...
"buening" said:Has anyone commented on the lack of export brace on your car? I'd highly recommend getting one, even if it is the stock 2-piece one. If you've heard this many times I apologize :scar
"AzPete" said:The new position is better but still think it can be better. On that fuel line, you could run it as you showed in the second picture for the carb, going to the rear, then take the flexible line with a filter and loop it to the existing side it is hooked to, going under the regulator.
Hmm no one's mentioned that before. That filter was a PO thing. I'll look around for a differnt kind though if that one isn't safe!I didn't catch if anyone warned you yet but that glass fuel filter is not a great idea. If it breaks you end up pumping gas all over your nice hot engine (in your case right onto your headers!)
"Horseplay" said:I used them for a lot of years as well, Mel, without incident. That doesn't make it the best thing to do. The thing is it only takes that one break to cause a very dangerous situation. For a very little amount of cash you can swap out to something much safer.
