daveSanborn
6000 RPM shifts with no problems.
Sons car has a 3.90 geared rearend and 1st gear is damn near useless. I wouldn't go with a 4.11 if it's going to see 90% street driving. If anything, I'd go with a numerically lower gear ratio such as a 3.50 or at the lowest end a 3.25.
The T-56 should require extensive tunnel modifications in order to maintain acceptable driveline angles, yet Darreld installed one in his '68 only by using RM adjustable (lowered) engine mounts.
He is a salesman for the aforementioned company. He googles the company name and then joins internet forums to tout/defend his companies product. He's more argumentative than I am.... if that's possible. I'd refrain from mentioning his companies name or else he will show up here.
Three years ago we purchased the TKO swap kit from DarkHorse and it was approx. $2800. It included everything from the engine block plate to the shifter ball and everything in between. The only additional items we had to procure were the driveshaft (Inland Empire), a plug for the mechanical speedometer port on the trans (Steeda) and a pigtail to connect the electric speedometer (local Ford dealer). The kit included the at that time available JMC hydraulic clutch kit.
What's the story on him?
