tarafied1
a little, not ready to chop any tops but...
I was thinking (uh oh), I have several stock steel hoods. two with the turn signal vents and one with a Boss9 scoop. What if I make a steel hood to fit my Ecar nose?
I could use the best hood, cut the front off. Then cut the front off a doner, longer by the length of the Shelby Ecar nose. Roughly an inch or so. Of course the hood gets narrower toward the front so I would have to narrow the longer front section before attatching it. Since the "bead" or whatever you would call it runs down the center, I would keep that one peice and section some metal out of either side to narrow it.
