Just got a 68' mustang!
I'd start with replacing the foil with proper fuses.
You have your work cut out for you thats for sure. Nothing too bad tho
IS THAT A FUEL LINE COMING THRU THE FIREWALL BY THE GAS PEDAL!?:eek:
The wire hanging down in the corner under vent is for the dimmer switch for high beams.
Alright! Thank you! Also, I forgot to mention, wiggling the shifter and turning the key did not work unfortunately, should I get a new switch as well?
Sent from my MotoG3 using Tapatalk
In bold, next to photos:
Okay sounds good! Here's a few pics
White curved connector pair: turn signal switch wiring
flat red 3 female pin, 2 wires: lead for accessory lamps on dash lamp circuit
Black 90* pair on metal can: turn signal flasher can
2 pin female pin (yellow/black, 2 blue/red wires): radio power, lamp connector
Way in back: black connector w/2 green wires: brake switch
See above for most; cylindrical object with spliced wires: that's your ignition switch
Not much here; wires on bottom left are for dimmer switch
Dimmer switch down below; tail-light and headlight connectors on upper left.
Too dark to tell what this is.
See above; wire circling up on right may be speedometer cable.
Connectors for engine gauge feed harness (flat 3 pin), pair of 2 pins: neutral safety switch and backup lights; four pin square connector: wiper motor. Plug at bottom right is for hood turn signals (optional).
Starter solenoid. From left to right: battery post, S or start cranking signal, I or coil power while cranking, and starter cable.
A 68 coupe in what appears to be Kansas/Nebraska.
