Leaky Fuel pump
eZ65
The fuel pump is new on my 5.0. The car has sat for about 5 months and now after driving it up and down the street today to get it to running temp the fuel pump is leaking a bit. Is it just a gasket or is this a good excuse to upgrade the fuel pump?
leaking fuel when the car is running hot you can see the fuel bublle up in the little black tabs
[attachment deleted by admin]
here is a better pic. i whiped it down the turned the car back on...you can see the gas coming up from the black holes...is that just a gasket??
Those black holes are threaded holes which keep the bottom half attached to the top half. That is a thick rubber diaphragm between the two. You might be able to get a replacement diaphragm for your pump. Also check to make sure those bolts are snug, as a loose one might cause the seep. If all else fails, pumps are cheap! Good luck!
