"Horseplay" said:It takes the force of the rocker to push the valve open and hold it open against the tension of the valve spring. In order for the valve to "slap" against the valve seat (head) you would have to in some way have the rocker release from the valve tip allowing it to move freely. The only way I see this happening is if you had a serious flat spot in the profile of the cam lobe that let the rocker come loose.
Ouch! anyway to check with-out tearing it down?
