chillininnh
Well I bit the bullet today and removed the booster from the car. Removed the drivers seat and for all my procrastinating on this, it didn't come out too bad. It's an original 69 power brake disc/drum system, no power steering. I was sure I had a vacuum leak and after going through everything else it was clear that damn booster was fubar. Some solid advise is what I need at this stage. This engine only produces 8 inches of vacuum at idle. It is a 418W, the engine builder warned me running power brakes may be problematic. The booster had quite a bit of fluid in it. It was one of the only parts during the restore that I chose to reuse, bad decision lol. Should I try a Booster Dewey rebuild and see if the brakes will be right with such low vacuum? I'd hate to go that route, reassemble the thing and not have it work correctly. I know you like pics:
Under the circumstances it seems I would be wise to convert to a manual brake setup. I know I'll need a manual pedal and that the power pedal support will work with some effort. A 74 maverick master seems to be the popular choice and an adjustable master rod too. What happens with distribution block? What kind of changes to the lines at the block need to happen? Am I missing anything for the swap? Is it possible I'm overthinking this thing and that I should have the booster rebuilt and try it? Good weather is coming and I gotta move forward one way or the other. Thanks in advance.
