Painted both horns semi gloss black and installed, bead blasted and primered dual exhaust reinforcing plates, primered and test fit. Had to remove some seam sealer to get the plates to fit tight.
"stangg" said:Another option for chroming...
http://www.mustangcorral.com/cgi-bin/cp-app.cgi?usr=51F1514253&rnd=3502748&rrc=N&affl=&cip=&act=&aff=&pg=prod&ref=clvent&cat=excl&catstr=HOME:cl:excl
I got my vent window frames from Mustang Corral back in 2007 and very pleased with the chroming quality. They basically take your frames as a core and ship you out a set they already have on hand. The chrome looks great but if you are concerned with every detail being perfect then you may want to call them first. The only issue with the ones I received is that the little V detail at the lower front corner was somewhat sanded out... probably to remove some light pitting. In my opinion a very minor deviation for a non concourse type car. No one has ever commented on them and I've seen several other high end cars with the same issue so hardly a concern for me. For $225, plus shipping and cores, I think it's a very good alternative...
Two weeks ago I found an OUTSTANDING buy on a pair of the best aluminum SBF heads Ive seen in a LOOOOONG time so even though I wasn't quite ready to make the buy I couldn't pass them up. Got'em for at LEAST $400 under MSRP and I am one happy Mustanger !!! They arrived last Monday so I had to wait a week to inspect them. These are some SEXY heads !!Tack it. There is no need to ever adjust it once set to the right length.You may want to think about putting a jam nut on to keep the union from adjusting during use.
