Just make sure if you are going to make a long extension cord to run a big amp draw item like a compressor you take wire size into consideration. That goes for the wiring to the "dryer" outlet as well. It was sized to carry the typical dryer load at a particular distance from the main box. Depending upon age of your house(wiring) and quality of construction, you might find the original wiring is not up to the task.
I'd first check to see if you don't have two separate 120vac circuits already in your garage space. Your outside coach lights might be wired on a diff circuit than the lights/outlets in the garage, for example. Or maybe the lights and outlets are on diff circuits. If you have two circuits...you got 220. Might be easier and safer to wire up from those sources. Just something to consider.
Big amp draw items and long cords are rarely a good way to go.
