68angrypony
Asking 450 obo
Up for sale is a Super S-32p. It is a Miller welder. Light weight, wire feeder.
Processes are: MIG (GNAW) Welding and Flux Cored (FCAW) Welding. (Gas and Self-Shielded).
Applications: Ship building, Construction, Pipe Welding, Field maintenance and repair, In-plan maintenance, Outdoor equipment repair.
Features: Impact-resistant, flame-retardant case, Totally enclosed, Non-conductive case, Quick-change drive rolls, gas purge, wire jog control, insulated gun-holding bracket, overload protection, solid-state speed control and brake circuit, light weigh, suite case-type feeder, industrial, high-torque, 24 VDC drive motor, operates on open-circuit and arc voltages, Voltage-sensing control circuit with cc/cv switch.
input power: operates on open-circut voltage and arc voltage 15 to 100v
electrode wire diameter capacity: .03-5/64in (0.6-2.0mm)
Maximum Spool Size Capacity: 30lb (13.6 kg) 12in (304 mm)
Wire Speed: 50-700 IPM (1.3-700 m/min) Actual range in CC mode is dependent on arc voltage applied.
Dimensions: H: 15-3/4 in (400mm) W: 8-3/4 in (222mm) D: 22-1/2 in (572mm)
Net Weight: 32lb (15kg)
Whats in the picture is what you get. The welder with the wire that is inside of it. It is for local pickup. I can possibly meet/deliver if pre arranged. Possibility of shipping completely at the buyers expense which based on the weight and dimensions I would say would be 50 to 100 dollars.
Please ask any and all questions before the end of the auction.
Thank you,
