Need help with missing parts
attached is a pic of 2 missing brake drum parts i need. Anyone know there names so I can do a part search for them? Or maybe where to get them?
The pin on the left is your brake shoe retaining spring pin. The larger part is your self-adjusting wheel. Your local auto parts store should sell a drum brake rebuild kit that I know will have new pins, but I'm unsure if it comes with a new adjusting wheel. Try your local auto parts store before scrounging anywhere else. The rebuild kits are usually pretty cheap in price.
As Dave said, your local auto parts store will be able to help you. You'll need a hardware kit (sometimes called a spring kit) and the Adjuster kit. The hardware kit will come with everything but the adjusters for both sides. The adjuster kits need to be bought per side. The adjusters are specific for left and right side. Have the parts store label the box left or right so you dont mix them up.
I need these 2 parts to do the driver side drum. Finished assembly of the passenger one then went to do the driver side and realized these 2 parts were missing
Thanks for your help guys
The rebuild kits are pretty cheap. If you don't want to go that route, I just took my back ones off. They should be the same (not sure though). If you want them and pay the shipping, you can have them. Might be cheaper to get the rebuild kit though.
The self adjuster kit is $9.99 per side and the spring kit with the pins is $8.99 for both sides at Autozone.
Personally I don't skimp on brakes and just change out the hardware when I change the shoes.
I probably have the parts you need in a recycling bin, like above, free plus shipping.
