Fst Blk
It will not take him long and he will be wishing for a bigger space.
Yup...
Overkill. As long as the OSB is kept from moisture it is very stable and does a good job. Why in the world would you want to pay 5-6 TIMES the cost for a material that is not needed? You realize that is THOUSANDS in additional cost that is completely unwarranted. I think Bill could spend that $4k+ elsewhere much more wisely. Like a lift, compressor, tool chest, tools....looking good but I would never use chipboard for anything. I's use marine grade plywood.
OSB is the industry standard for sheathing buildings. Properly sealed from the elements it will last forever.
Great looking building, but it is getting smaller by the day as it starts being closed in. No doubt you will enjoy having it done and usable.
When is the central heat/AC going to be installed?
Shoot I used OSB on the outside and inside of my shop. By the time you figure finishing of the drywall costs it was just as cheap to use the OSB, paint it and your fine. Bonus is you can hang things basically anywhere unless it's real heavy. Then you still need to find a stud.We put advantech on the flooring but no way I would have on the outside. 45 bux as opposed to 17. We are wrapping in tyvek. This is what houses are sheathed with in my area.
I found out the other day that apparently a LOT of mobile homes are sheathed with 3/8" styrofoam that has been coated with a thin tar-like susbstance. So apparently the OSB I also used to sheath my garage is massive overkill.I'm happy I built it some years ago. I got into another project recently and about every time I go to get more supplies how much the prices have risen about floors me. Most recently nine freaking dollars for a modestly sized box of deck screws. Basically a big handful. Gads.
That's just plain wrong. Everything has it's purpose and place and if used within the confines of its design stuff can be extremely durable. In the case of OSB it can last a LIFETIME if used in accordance to this rule. Prolonged exposure to moisture is about its only weakness compared to "regular" plywood.I build once for longer than life. OSB is garbage in my mind.
Too each their own I suppose. Makes the world spin.I build once for longer than life. OSB is garbage in my mind.
