The dipstick is in the oil pan on the 5.0 so you would need to drill into the timing chain cover to put in a 289 dipstick tube in.
My '88 5.0L had a fuel pump eccentric. It also had blanks for the dipstick and mech. fuel pump. :wtf"Fast68back" said:You could also swap the timing cover with a early model one that has the dip stick port and the fuel pump opening if you plan to ditch the EFI stuff for a traditional manifold and carb.
I assume they dont put the fuel pump eccentric on the motors at the factory though so you would have to add one?
"gotstang" said:My '88 5.0L had a fuel pump eccentric. It also had blanks for the dipstick and mech. fuel pump. :wtf
"mustangstofear" said:The 5.0 are a pretty simple set up, and are commonly done. We are going to be doing a 4.6 or a 5.4 shelby motor in a 65 fastback soon. We always use the Rod & Custom set up. Next week we are doing a 69 fastback with a real boss 429 but with the Rod & custom set up. Rich
