southern_boy
I'm sure you all remember me having my no spark/no start issue with my 1973 Mach 1 351 Cleveland. I have decided to just switch it to a Summit Racing HEI set up, and hope that works. I read the instructions that should come with it and it says Reconnect the wire leading from the ignition strip to the distributor. and plug the pickup lead connector into the new distributor cap. where would the lead wire from the ignition strip to the distributor be? and is the pickup lead something this HEI should Come with? And if anything can make the car run the way it is will the HEI make it work. Considering it has gas, just no fire even with a full 12 volts running to the coil from the battery.
