Opentracker
Try one of these Lincoln 135's - they are cheap and they work great. They are on ebay used.
http://www.ebay.com/itm/Lincoln-Mig-135 ... 20cc6c97a8
"tarafied1" said:Im a hack welder but a good grinder ( ask Bill) and i drive the crap out of my car every year. No broken welds yet.
that reminds me, if you buy a nice welder, be sure to get a good grinder too...."67 Fastback" said:He burnt up my favorite grinder :nutbj
Bill
Bill
"stangg" said:If your looking to get a welder to keep for the longer term, get one with a variable voltage control. It's much easier to dial in the voltage than with the standard 135's 4 fixed voltage settings...
As mentioned above also, absolutely be sure to V groove when your welding thicker stock... The point of the V groove is it gives you a much wider surface area and much better penetration across a wider area with a side benefit of not standing too proud of the surface, so less grinding for cleanup.
I don't have shock towers so I don't know.... but aren't the towers too thick for a 135-140 amp welder? It seems for something like this you'd want a 175-180 amp welder.
"Opentracker" said:Try one of these Lincoln 135's - they are cheap and they work great. They are on eBay used.
http://www.eBay.com/itm/Lincoln-Mig-135 ... 20cc6c97a8
