66gt350
On the wife's 65, she only has one brake light, the right. Both blinkers work correctly, and she can get both the brake lights to work if she holds up slightly on the turn signal lever. I'm assuming that the turn signal mechanism is DOA. Typically, is this something that can be repaired, or should I just break down and get her a new turn signal wiring harness.
thanks
thanks
