Could use a sanity check here. Son's new to us 69 2-barrel 351w Cougar started misfiring and popping through exhaust. Since this was immediately after some (ahem) unsupervised parking lot donuts, I first thought he might have jumped a tooth on the timing gear or bent a valve or pushrod. However, a compression test had every cylinder at 165-170 PSI. I also checked rotor backlash on the timing chain slack and it.s maybe 5 or 6 degrees max. So I think the mechanical valve timing is cool. Would anyone disagree?
Moving on to the distributor timing, I found it was at almost 19 degrees initial, going to 30 total at 3,000RPM so only 11 or so mechanical advance. This is without vacuum advance hooked up. I don't know what the timing was before b/c the car is a with us a week and I never checked it before. This is also somewhat suspect because the car is running like crap and needs 1000 or so RPM to idle on its own with popping and missing.
We just soaked and rebuilt the edelbrock carb and installed new fuel filter. Ordered a new gas tank due to rusty particles throughout carb and inside cut open fuel filter. No change at all. (Well it's a lot cleaner... )
I'm beginning to suspect the pertronix... Just because it's there and it's voodoo. I read about making sure the gap is correct on the unit, and the height of the push on magnet ring is the same as the pertronix unit... Checked and tweaked both and still no dice. How do you troubleshoot these things?
Oh and one Other thing- let's say I pop on an old distributor with points etc and the one wire as a diagnosis aid. This car has a full 12.3v to the hot side of the coil. Isn't that too much for points? Does the black wire from the points go the negative side of coil? It's been many many years since I've screwed with points
