68EFIvert
I am tired of my windows coming up very slowly so I have decided to rewire them with the addition of relays. I am already in the final stages of rewiring the entire car with an AAW kit so this falls under the "may as well" category. I think I have the basics but I want to run it by you guys to see before going too far. I know I will need two relays for each window, one for the up switch and one for down. Here is what I think is correct for the connections to the relay.
12v fused power to 85 and 87
87A Ground
86 to window switch
30 to power window motor
I am not sure about a couple things on the wiring. Do I still need to run the 12v power to the switch? How about a ground to the switch? If I do, I assume I can just tie into them and not run a seperate power supply? I know I will still have an illumination wire to the switch but I an not sure what the different letters mean on the back of the switch. I have interpreted it as follows:
Can you guys tell me that the different letters mean or confirm this is correct?
D - To Motor (up?)
C- Ground with a jump to B
A- Power
B- Ground jumped to C
E- To motor (down?)
L- Light for switch.
Does it sound like I am going in the right direction? Thanks for the help!
87A Ground
86 to window switch
D - To Motor (up?)
A- Power
E- To motor (down?)
