"silverblueBP" said:You can also flip the drums and use them as a slide hammer if needed.
OH yeah.... something you never forget...P.S. Old gear oil has a unique smell that will stay with you for a while...
"AzPete" said:The gears are heavy coming out of the housing.....be ready and then think about a jack of some sort.....
"daveSanborn" said:+1
If you haven't been to the gym in a while you'll be reminded VERY quickly just how heavy 80+ pounds is as it falls on your head/chest/arm/shoulder/fingers. Be careful and DO NOT under-estimate the weight of the third member as it seperates from the housing.
Do you think it will come out ok?
"66gt350" said:One of these days when I'm ambitious, I'm gonna drill and tap a hole in the bottom of housing, to drain out the lube.
