DougG69
So am I stuck using Windex and/or soapy water and a razor blade, or is there an easier way?
"DougG69" said:So am I stuck using Windex and/or soapy water and a razor blade, or is there an easier way?
"AzPete" said:Wow...I have never scratched the glass with the 0000 grit steel wool. You have to be gentle but it also depends on how heavy the paint is.
"mustangstofear" said:Boys, I have been painting cars for forty years all you have to do is soften with some lacquer thinner and scrap it with a new razor blade and glass cleaner. Always make sure it is wet and you won't ever scratch your glass. Rich.
"SELLERSRODSHOP" said:+1. the keyword is NEW razor blade. if you think you have hit the edge on something, get another new one out & use it. a box of blades is much cheaper than a new w/s. keep it lubed good with plenty of glass cleaner. the foamy kind works well for this proceedure.
"mustangstofear" said:And maybe next time try a thing called masking paper and tape. Rich :ecit
"mustangstofear" said:Where do you live in Indiana, we are 90 mi. north of Indy on 31. Rich.
"BobV" said:Use a clay bar - worked great for me. :5
"mustangstofear" said:Wow, I can't believe you know my buddy Mark. Man what a small world. Mark is about 50 min. away. You should stop up at my place, I have about 9 builds going on. Rich.
