daveSanborn
Scott Drake is NOT a classic Mustang parts vendor. Scott Drake is a classic Mustang parts "supplier". Scott Darke is not a retail operation and you cannot order anything from them unless you are a parts vendor. Many of the Mustang parts houses carry Scott Drake reproduction pieces and the quality is usually pretty high. If your search for a particular Scott Drake item through the various parts vendors yeilds negative results due to "this item is temporarily out of stock", a trick I've discovered is that you can call Scott Drake and ask them when they expect to start filling these backorders. Scott Drake will even tell you whose (which vendor) backorders are being filled first and on what date. With this information, you can then make arrangements with that particular vendor to get on a waiting list for the item.
This is not really a "vendor evaluation" topic, but it seems to be a better place than anywhere else to place this information.
