Dne'
I had these questions on my intake manifold thread, so I'm asking the questions again here.
1) I started my motor and it wouldn't stop running. I bopped the started solenoid and it died. Now it starts up and dies ok. The smaller solenoid wire I understand that cranks the motor, but the ignition terminal I don't! I have the electric choke, fan relay(for my electric radiator fans), and the wire for the coil. Is this too much current for this terminal(the photo doesn't show the wire from my electric choke)? The solenoid was stuck so the motor wouldn't die until I tapped the solenoid. The electric choke on the carb gets REALLY hot.
2) I mentioned about my alternator is not charging still despite reving the motor. I do have a Tuff Stuff Chrome 100amp alternator, but I lost the instructions of where to run the wires, mainly the smaller wires coming out of the side of the new alt. I understand to run a larger gauge wire to the positive side of the starter solenoid, but the other two wires have me stumped. After I've installed the alternator, what do I do with the plug that went to the existing voltage regulator, and the wires that went to the older style alternator, and how do I make the ammeter work? am I asking too much? lol
Thank you!
dne'
![IMG_8566.jpg](http://img.photobucket.com/albums/v417/Denee/IMG_8566.jpg)
Thank you!
dne'
