Finished the fuel system on the 68 today. Took a while to get gas up to the carb, so it cranked quite a bit. Finally starts and is running great, but engine speed increases, forgot to hook up the return spring on the carb. Shut it off, attach spring. Try to start it again and relay makes a click/clunk/buzz noise but makes connection and spins starter. Engine won't fire.
I trigger the MSD box with the original + coil wire which in start mode should provide 12v to the relay turn on the box. If I understand the circuit correctly, during starting mode the 12v to the + side of the coil comes from the I post on the relay. So then I wondered if the relay is bad based on the noises I heard. The next time I crank it, it doesn't start and the starter won't stop. Had to pull the cable off the battery. So to get to my question, when the S terminal energizes the relay, does the relay pass 12v to the I post? Could whatever fried inside be the reason the MSD won't trigger on through the coil wire? Decided to mess with it tomorrow, get a new relay and start checking voltage in the ignition system. Am I on the right track or is it two separate problems? Any of you wise men have any ideas?
