Stop fuel spills- filler neck modification
Hey Terry. (I'm a little late to the party...) How has this modification worked in your car? Success?
I assume you are asking Horseplay-Terry, and not Mach1 Driver-Terry? I haven't seen any updates from Horseplay, but mine works just fine and the best modification I ever made to the car. I would cuss the damn thing every time I filled-up, but now its no problem.
I don't really know if I still get fuel sloshing out the back when accelerating with a full tank. I don't think so, but I intend to get rid of the carb and go to EFI. I will get a new tank with the pump in it. It will have the fuel line, return, and a separate vent, then I will use a non-vented sealed cap and that will be the last of that problem, if it still exists.
TERRY will never drive his car to find out [emoji23]
Ha Ha. Yes, my car failed yet again to make it to the street this past season so no actual results can be fairly given on the filler neck mod. I can tell you, however, that is now matches millions of other set-ups on cars that get filled up routinely at the pump (much like my own daily drivers) so I don't expect any issues.
