and all this time I thought you were in Iraq.... :lol"fordrule" said:I am actually in Nashviile area. I am an hr from jonk and from craig. Clarksville Tn./Fort Campbell . I can pm you my address
"janschutz" said:I am also supplying
Intake
front oil pump and pan
water pump and pulley
coil and mount
valve covers (need more bolts to hold them on)
Alternator and brackets
spark plugs (used)
I also have a radiator but I do not know if it will fit a 65-66 since it came out of my 68.
Things I now it needs
exhaust manifolds
distributor
crank pulley
carburetor
plug wires (I have an old set with a distributor cap, but they are just my emergency wires)
motor mounts (I have a passenger side he can have)
"janschutz" said:Updated the pictures of the engine to show what is on it.
Needs correct bolt and spaced for alternator, bolts for valve covers and to mount dipstick tube. Need Return heater hose elbow for intake.
Need crank pulley, fuel pump, temp ending unit, carb, Radiator hoses, fan and space. Have water pump pulley to put on.
You need valve cover gaskets and I would also replace the front seal.
