Dne'
I've been working on connecting my flaming river steering column turn signal switch today. I'm having some problems. The main flasher for starters~ Is the turn signal flasher hot at one lead going into it and dim lit on the other side when not in use? and the same question for the emergency flasher. the little flasher looks to be original and was hot on both leads going in and out of the flasher~ I took it apart and it appears to be old and burned up. I replaced it with a heavy duty flasher and now it's hot on one side and dim lit on the other side when plugged in. I don't have any lights connected right now as the fenders aren't on and neither are the tail lights.
Before I had replaced the old flasher~ I could turn the turnsignal to the right and my test light would light up and same for the left at the plug where the lights plug in. When I installed my new flasher, the plugs where the lights plug in show a dim lit test light.
If I had bulbs in front and rear, would that make the flasher work?
dne'
dne'
