66benchcoupe
A few comments.
Don't rely on initial timing, set the timing with all the advance dialed in. I suggest 34 degrees total timing as a safe starting point. Read the instructions for the Pertronix dizzy you bought, that should tell you at what RPM the timing is fully advanced. Rev the engine to that RPM and set with your timing light. BE SAFE, stand back or to the side in case the fan or a fan belt comes apart. Wear safety glasses.
The carb. Set the parking brake and put the axle on stands, chock the front wheels. Lightly seat the idle mixture screws and then turn out 2 turns. Attach a vaccum gauge to an unported vaccum source (manifold vaccum). Start the car and put the trans in D. Set the idle adjustment screw as low as it will idle in gear and start turning the idle mixture screw in at 1\8th turn increments until you get the highest reading on the vaccum gauge. At that point back out the adjusting screws 1/8 to 1/4 turn, vaccum will drop slightly. Your idle mixture should be set properly at that point. If you still have issues with the carb then the problem lies elsewhere (float level, the secondary system, etc.). The instructions assume your ignition system is functioning properly and you have no vaccum leaks. There's lots of variables here so take it a step at a time. If you get angry or frustrated, just walk away and cool off.
I suggest reading "How to Build Horsepower Vol.2 - Carburetors and Intake Manifolds" by David Vizard. I've read several books on carburetors and this one explains how they work very well. A book is no substitute for experience but a little knowledge goes a long way when you're trying to diagnose a problem Unfortunately, this book is out of print but is still offered by some sellers on the internet.
And if you can find a Barry Grant carburetor and technical info catalog there's some really good tips in it.
Good Luck,
Robert
Good Luck,
Robert
