manley
I watched the show. It was really great. When they get back to the island, I hope they discover the plane in the deep water. It would be nice to know the end of the tale.
"lethal289" said:i thought the show was well put together. Randy, have you ever gone on one of those expeditions?
"Opentracker" said:That was a great show. Lot's of new information for me. I do hope they find part or all of the plane in the deep water search.
One thing though, something that drives me up the freekin wall about regular TV. Seven minutes of show followed by 4 minutes of commercials, over and over and over. In a two hour show you get over half an hour of commercials. :rant I must just be getting old.
I watched as well. I'm not sure I followed the footage showing the puff of smoke behind the tail on takeoff being the snap of the radio receiving antenna breaking. If it was under high tension or if it was a heavy cable, then the noticeable reaction hitting the runway? The story goes that the cable was under some tension, but with a heavily overloaded plane and a grass runway, the rear mast snagged on a mogul. It had rained earlier that morning, so the "smoke" may have been water sprayed up from the breakage. There's an unconfirmed anecdote that folks found a cable on the runway after the take-offAnyway, it was a better explanation of why Amelia couldn't hear the Itasca's transmission, than the Hillary Swank movie version that some Navy seaman let a battery run down. IIRC from the show last night they said she still would have received short range transmission with the top wire? The top wire is actually the RDF receiver, which should have been able to hear signals, but not RDF on signals above 1400 kHz. Since AE had a main receiver antenna, why use a secondary antenna (RDF antenna) when the other one should work? If course, she had no idea it had broke off.I would have assumed she would have done a radio check shortly after taking off? We've learned never to assume anything logical with Earhart. She did do a radio check the day before, and the radioman had problems hearing her well, and she had a very loud signal from Lae.
And what was it with the British putting 20 settlers on the island before WWII? an island with no water, no soil--made me think of Papillon. The colonists knew how and where to build wells for fresh water on coral atolls; there simply isn't any fresh water on the surface that is easy to get at. They did have problems until the well was dug.
