:lol yes they do, but when you try to get 2000+ cars in a fairgrounds or school or something like that, it gets backed up and you sit a lot."Midlife" said:I thought the Power Tour typically travels at speeds greater than the highway limit...
I guess you could be right about the T-stat, the heat on the floor is just radiating from the box I think, I've checked the doors and they close okay."AzPete" said:A 160 degree thermostat will do more bad than good. Once the engine temps reach 160..you get maybe one open close cycle and then the thermostat will open and never close to allow the water in the rad. to get any cooling time.
You could go under the hood and temp. mount a couple of the small 6" fans that you plug into your lighter socket. That would give a bit more air flow at parked speeds and can be removed easy.
Did I read that the heater makes your wifes feet hot??? That means the doors are not adjusted correctly to cut off the air flow thru the heater core.
"hivewax" said:Another option is temporary/permanently remove heater hoses and box.
