A
Anonymous
Guest
"opentrackerSteve" said:I got my pro motorsports kit installed. Last Saturday, I got the car down to the alignment shop and they aligned it to:
camber: -2.7 deg on both sides
caster: +2.1 degrees on both sides
toe: 1/8 in
I'll throw a kink at you....try some toe OUT when you go to the track. +1/8"- +1/4" and you'll see it helps turn in. I'm running + 1/4" and it has no ill side effects at high straight line speeds.
