Fast68back
Guest
Align pulleys? I FINALLY got around to trying to install the new KRC pump I got from Shaun at Street or Track and the pulleys do not line up with the March pulleys I am using. The kit came with a couple washers to use to get the final spacing down, but I think I may need to go a little thicker than the washer to get the to line up. Other than eyeballing them, is there a tried and true method to line them up correctly?
Also, where should I place the additional spacers? Sorry for the crappy cell pictures, but from the head there are two spacers on each of the three mounting bolts, the bracket and then the pump itself. I really do not want to space behind the pump/in front of bracket as I like that the pump sits flush on the bracket. Should I space behind the bracket? In front of the heads or between the spacers?
