66gt350
Ok...I'm looking at getting rid of some of my under hood and under dash wires, and I wanna double check to make sure that they aren't used for anything else.
I no longer have the stock dash, so I'm not using the ammeter gauge anymore. There's red and yellow wires going between it and the starter relay. And from what I can tell from the wiring diagrams, that all they are there for. Same thing with the pink resistor wire. I'm no longer using the stock coil, I've got a Mallory Hifire VII in there, and it feeds off of 12 volts, so that wire is just sitting there. Do those wire's have any other purpose in life? Can I grab the wire cutters and remove those wires or should I leave 'em?
thanks
-rob
thanks
-rob
