tarafied1
that's not a bad idea!"janschutz" said:Looks great. Keep the 16 gallon tank and stack them, then you could keep up with Larry! :dun
I have two teenage boys, no gas fairy in sight!"Laurie S." said:I find that gas fairies solve all my fueling problems.
What size tank are you running, John? 20, or 22?"janschutz" said:Craig,
I just ran out of gas with my new tank but could only put 18 gallons in. I suspect that the siphon tube is not low enough. I now have an extra gallon container filled in the trunk and will run it out of gas again to check.
Just something else to check before the power tour. Do not want you to run out when you think you still should have plenty to go.
22"Midlife" said:What size tank are you running, John? 20, or 22?"janschutz" said:Craig,
You are correct Craig. At least that is what I think. I have about another 100 miles to drive until I know for sure."tarafied1" said:I think he is saying the pick-up is not low enough in the tank to fully utilize all the fuel that is in the tank, therefore he "ran out" with gas still in the tank. If I understand him correctly
"68angrypony" said:Im in so cal. I know in some of the other stats you guys have the pumps with the metal filler and no rubber surround. In so cal we have a rubber boot that seals around gas fill hole. Do you know with that set up at the gas station if there are still issues?
