Clutch Recommendations
Discussion in 'Engine and Drivetrain/Mechanical' started by One_fast67, Feb 22, 2018.
  1. One_fast67
    One_fast67 Member
    I am in the home stretch of finalizing my driveline components but I still have a few details to work out. First, here is what I already have nailed down: 408W power plant in front of a Tremec TKO600 transmission going to a 9” rear with 3.89 gears and a tru-track limited slip differential. Going between the transmission and the engine will be a Quick Time (RM-6065) scattershield. I’m looking for clutch recommendations in this setup. I also haven’t decided whether or not I am going with a mechanical or hydraulic clutch linkage setup. Recommendations?
  2. B67FSTB
    Would defenitely go for hydraulic clutch.
    Clutch ? How you gonna use that car ? Street , Circuit , Strip ?
    I would contact McLeod , Centerforce.
  3. One_fast67
    One_fast67 Member
    This car will predominantly be a street car but I can’t rule out some spirited driving events. I was looking at McLeod and it looks like there is quite a range of options. I am hoping to get some feedback from the group to understand if the $990 option is overkill or the $370 option is not good enough. The recommendations offered up by the manufacturer are fine but I would rather get the opinions of people that have actual experience.
  4. msell66
    Centerforce dual friction is my street/track go to.
    Boom likes this.
  5. One_fast67
    One_fast67 Member
    Thanks Mark. If I have filtered my requirements correctly, it looks like my application would require P/N DF161830. It will mount up to my Windsor block, the clutch disk doesn’t exceed the 10.5” maximum diameter specified by the scattershild requirements, and mates to a 26 spline input shaft as needed for my Tremec transmission.
    Is there anyone running this specific clutch or have other recommendations?
  6. 3175375
    3175375 Well-Known Member
    I would recommend Centerforce
  7. Boom
    Boom Active Member
    I have a CF dual friction on my coupe with a T5, excellent clutch.
