YOU KNOW it's not orange. It's dark red. Camera and lighting affect, I guess.Why is the water pump orange?
When I first attached the metal shields I used seam sealer to seal and fill the contact points all around the apron. Then everything got sprayed with Raptor liner. When I attached the rubber pieces I used urethane adhesive not only to attached them to the metal shields but also built up a seal around the points of contact to keep water from having a path in between where it could sit and potentially cause corrosion/rust down the road. I cut the ends off the screws where they came through and covered them with a dab of the urethane too. Overkill for sure given the shape the originals were in but at this point I have gone to such lengths on everything so why stop now. You may notice that except for where grade 8 strength bolts were needed I used nothing but SS hardware throughout. The cost has been stupid but why ruin the appearance with a nasty old rusty bolt?!Awesome looking Terry. I like how you did your splash shields also. Got a pic of the front side of them?
Thanks for the info. I have to redo mine here soon.When I first attached the metal shields I used seam sealer to seal and fill the contact points all around the apron. Then everything got sprayed with Raptor liner. When I attached the rubber pieces I used urethane adhesive not only to attached them to the metal shields but also built up a seal around the points of contact to keep water from having a path in between where it could sit and potentially cause corrosion/rust down the road. I cut the ends off the screws where they came through and covered them with a dab of the urethane too. Overkill for sure given the shape the originals were in but at this point I have gone to such lengths on everything so why stop now. You may notice that except for where grade 8 strength bolts were needed I used nothing but SS hardware throughout. The cost has been stupid but why ruin the appearance with a nasty old rusty bolt?!
+1. Wow.That console is awesome. Made from scratch??? How much to make me one lol.
Funny guy. Actually there will be a LED inside that will come on when the door is raised. Same for the rear storage box. Fuses rarely blow in the daylight hours.I like how you added the super high tech light in the fuse panel area.
66 T-Bird?Anyone want to guess where those rocker switches were originally used? I can tell you it is a vintage car...just not a mustang although they certainly look like they could have been original. At least I think so.
Nope. Here's a hint. Bruno might be more familiar with them.66 T-Bird?
