Fast68back
Guest
Mines under the dash...
"GTchris" said:What's wrong with the ignitor that goes in the distributor cap?
I didn't want to deal with points and didn't want the big box in my engine bay either. Then I saw the ignitor and thought that was the way to go.
"buckeyedemon" said:did you ever find a location for the MSD box? did this about three weeks ago. this was the only spot i could find. i didn't want it visible in the engine compartment as i'm trying to minimize the look of aftermarket toys. i do have access thru the glove box if i need to tune the limiters. this is a 69 without air conditioning.
"gotstang" said:The basic version of the ignitor doesn't have an adjustable rev limiter, the MSD box does. Past that, there aren't THAT many advantages to an MSD box over a 'normal' electronic ignition, IMHO, though the MSD is probably a much better choice for high RPM competition use.
"johnpro" said:Ford Muscle did an experiment at the track and the MSD 6-AL consistently dropped .3 seconds off of their time. That is very significant for a $150 bolt on part.
"apollard" said:They tested a complete MSD 6AL setup, including a new coil, against a standard pertronix, which is frankly little more than an electronic set of points (ie, same current, high resistance coil, etc). I've never seen a gain where MSDs have been tested agaisnt a modern, high current electronic ignition, like the HEI or TFI. But, I'm sure I haven't read everything.
"AtlantaSteve" said:Not downplaying the advantage the MSD gives, but the new Pertronix Ignitor IIIs have Multi-Spark Discharge across the entire RPM range, and a built in Rev Limiter.
Steve
"johnpro" said:Also, the Pertronix Ignitor I was fantastic. The Ignitor II ... well, not so much. I wouldn't be in the first wave of customers for any of their new products. :craz
