Mach1Mark's '65 coupe restomod
Discussion in 'Member's Build Threads' started by Mach1Mark, Jan 1, 2012.
  1. Mach1Mark
    Fab number two was the fuse panel bracket. I found out this week that American Autowire has revised the kit I bought a year ago to mount the fuse panel where I am mounting mine which was originally designed to be mounted to the firewall above the trans tunnel. It says right on the instructions that the fuse panel should not be anywhere else except above the trans tunnel, NOT for use with air conditioning. I still need to rivet the sides to the back and drill some mounting holes. Some primer and paint too.
  2. Mach1Mark
    Today I continued to fab the fuse panel mounting bracket (drilled mounting holes, riveted side supports, primered) and fabbed a copper jumper for the Mega fuses.
    Grabber70Mach and tarafied1 like this.
  3. Mach1Mark
    Drilled a couple of holes and painted the bracket, fabbed a 6 Ga wire.
