Mach1Mark's '65 coupe restomod
Discussion in 'Member's Build Threads' started by Mach1Mark, Jan 1, 2012.
  1. Horseplay
    My boy is headed home for the holidays and tells me he wants a ride in the car. So it looks like it'll be on the road this Christmas. So I think I beat Mark. I hope.
    Good decision, Mark. Keeps your project moving forward at a better pace.
    Mach1Mark likes this.
  2. kb3
    kb3 Well-Known Member
    without pictures, it never happened.....
    Grabber70Mach likes this.
  3. Mach1Mark
    Well . . . when did Terry say he would be operational?
    Today Im shopping for a battery.
  4. msell66
    msell66 Burning Fossil Fuels at c2 Donator
    Don’t worry, Terry will still be working on his car when the 2018 Power Tour starts.
  5. kb3
    fixed it for you, it appears you had a typo!
    msell66 likes this.
  6. Horseplay
    A real project car is NEVER done.
    tarafied1 and Mach1Mark like this.
  7. janschutz
    janschutz Corn Hauler
    Maybe never done but it can be driveable!
    tarafied1 likes this.
  8. Mach1Mark
    Purchased a new Motorcraft battery P/N BXT-24FA. 700 CCA. I discovered I need to remove my radiator overflow tank to get the battery in the tray.
  9. Mach1Mark
    Last weekend I finished the battery install including the remove & replace of the overflow tank. I removed the built-in handle on the battery for a cleaner look. Kept it intact in case it is needed at a later date.
    Today, I worked on installing the rear wiring harness and the fuel pump relay wiring. Had to remove the interior trim panel to access the area under/behind the quarter window guide. Fed the three (3) 12 ga fuel pump wires forward and the five (5) accessory wires rearward through the the plastic conduit and installed a hold-down clip.
  10. Boom
    Boom Active Member
    That inertia switch/relay combo looks slick. Whats it out of? Is the relay for the fuel pump?
  11. Mach1Mark
    It fits a number of late model Fords, found it on ebay. Came with short wiring harness.
  12. Mach1Mark
    Today I began filling the master cylinder and brake system with DOT 5 brake fluid. Going to push it to the rear brakes first tomorrow. Also continued to install the trunk wiring harness.
  13. Horseplay
    DOT 5 or DOT 5.1? 5 is silicone based and not recommended by just about anybody. Lots of potential issues and almost no advantages. Please clarify, Mark.
  14. Mach1Mark
    Hmmm . . . never heard of DOT 5.1 nor any negative reviews of DOT 5. I used DOT 5 when I raced my coupe. Its got a higher boiling point, doesn't absorb moisture from the air (hence slowing system corrosion) and doesn't ruin paint when in contact.
    A quick search results:
    http://www.epicbleedsolutions.com/resources/faq/difference-between-dot4-and-dot51-brake-fluid/
  15. msell66
    I bleed the brakes 4-6 times a year. Never had a problem with paint. Always use DOT 4 for track purposes. Never boils.
  16. msell66
  17. Mach1Mark
    Yesterday while bleeding the brake system I discovered I have a leak at the proportioning valve. Will elevate the car and attempt to tighten/repair the connection from underneath. More than a little frustrated but not really unexpected.
  18. Horseplay
    I feel ya. My custom brake line work is what cost me the tour this year. Beyond frustrating when something simple like that bites you. Took a while to sort mine out. Hope yours is an easy fix.
  19. msell66
    Yeah, THAT’S what did it.
  20. Horseplay
    The negatives I have read about relate to DOT 5 aerating easily, causing a soft pedal and it causing rubber seals to swell and fail in systems/components not designed to use a silicone fluid. That was enough for me to take a pass. Regular old fluid had never caused me issue anyway. My ability to distinguish between standard and AN fittings when hastily putting stuff together, that one bit me. o_O
