Yeah, that pretty much sums up his reply right there.Although, when I explained it to him, he said “That doesn’t make sense”.
Good thought I'm just not sure how the drum could be pulled out of round cinched to a flat surface if both contact surfaces have been verified to be flat. He has had the axles checked out as well as the drums turned/checked by reputable shops with this being one area of concern. He was at it again today working to find the issue. I'm convinced it is a combination of a couple things leading to the problem simply because everything anyone can come up with has been checked at least twice. Our floppy eared pal is frustrated for sure. He'll figure it out.
Not discounting at all. As a matter of fact you're on the same path I have been on with this since the start. Prior to this thread I asked Mark to take his axles over to the guy who built my rear end so they could check them out. And for the record, he has tried two sets of drums and had the first turned and then checked AGAIN to verify they were not out of round, etc. I'm of the mindset now that when torqued down something in the axles, studs, drum is getting, in technical terms, out of whack do to some incorrect contact surface issue. And to answer another question you pose, Mark says the the hub centric hubs fit perfect on the axle hubs.It sounds like you've discounted this idea because other "reputable" shops have looked at it.... yet none have come up with an answer.
I would be tempted to spray a light coat of paint inside the entire drum and then install it. Should rub the paint off somewhere!?
So, I changed from the stock 10x1 3/4 drum brakes to 11x2 1/4 last year. New everything including the backing plate. Since installation, I've had this same problem.
When I put the drum on the axle hub and then snug up the brake shoes so they just start to get drag, I can easily spin the axle with my hand. If I either tighten the drum down with lugnuts only of wheel and lugnuts, I can no longer turn the axle or tire by hand.
Things I've checked:
Axle flange runout checked out less than .003"
Axle is square to the flange
New axle bearings
Drums have been turned
Shoes sit fine depthwise into the drum. They are not touching the drum anywhere except the shoe face.
The shoes are the correct radius and fit the drums perfect.
I've used white chalk everywhere to see if there is rubbing. No witness marks other than the shoe face.
If I adjust the shoes in at the bottom so that when tightened down it does not affect turning by hand, the brakes don't do squat when the brake pedal is pressed. If I do adjust the shoes so they have the correct drag and then tighten them, I get major brake fade pretty quickly on track and the drums get super hot.
I have yet to check if the backing plate is square with the axle flange. That is the last thing I can think of to test. I've discussed this with John at ORP and he said no one else has had this problem with this larger brake kit.
I realize that due to the drugs I've had over the last 3 years, I'm limited in my ability to diagnose problems. So now, it's up to yoose guys!
New axle bearings
When there were only drum brakes and before automatic adjusters, I used to adjust then until the adjuster was tight and you could not turn the wheel in the forward direction. Then back it off until the wheel would almost turn freely. That way you were sure the shoes were centered. All done after turning the drums and radiusing the shoes to fit the drum. Nobody radiuses the shoes any more.
