Who?
I hear you but go look at their jacks. Mine are used ALL the time for a variety of vehicles and not an issue. EVER. Right now their 1.5 ton rapid pump aluminum is on sale for $70. Why spend hundreds more? Spend that cash on going faster!Harbor Freight for anything but disposable tools, is not a practice I could recommend...
I have a JEGs racing aluminum floor 3T floor jack. Have had it now for almost four years, easy on the arm and light weight (49lbs).
Definitely would take a look if I were you...
I'd rather spend more money on a jack that won't collapse on me when I don't want it to. Accidents do happen, and going cheap on raising/lowering a vehicle is not an area that I want to cheap out on.I hear you but go look at their jacks. Mine are used ALL the time for a variety of vehicles and not an issue. EVER. Right now their 1.5 ton rapid pump aluminum is on sale for $70. Why spend hundreds more? Spend that cash on going faster!
What part of my "review" did you guys miss where I wrote about the years (just shy of a decade now) have I been using these jacks without an issue? And as far as accidents go you should never work under a car sitting on a jack in the first place. A jack is to lift the car so you can place a jack stand or similar to support the load safely.I'd rather spend more money on a jack that won't collapse on me when I don't want it to. Accidents do happen, and going cheap on raising/lowering a vehicle is not an area that I want to cheap out on.
Not trying to start an argument just pointing out my actual experience and defending it against comments made by persons (in this case, Randy) who have obviously never owned or used one. I will say though, if you have had a HF jack fail on you share the tale although I'm thinking you would have earlier if that was the case.Just because you choose to use their overseas junk in a load bearing way, don't hate on me cause my choices are different than yours...
Somebody has to put the jack stands under the car...
I do have firsthand knowledge, so it is you with the preconceived notion about whether or not I have experience with a Chinese cheap jack failing, yeah it happens. Glad your luck has held out so long.. peace...
Who is Terry?
OK, Mr. Fourth place.
