interesting. I've made a similar and much less complicated mod that works quite well. It looks like his is also going to work well but a bit overkill and a lot of work. I have made a few variations for Stangfixers so I will let them speak for them selves but I have driven my car in 18 states and filled it at a lot of different stations. I can fill at full blast and the auto shut-off works. No splash back either. I welded mine and used engine paint. I've had no rust and no issue of sparking.
Somebody is watching their TV very intently! lolOne advantage is the flapper that helps prevent a surge of fuel out the rear from aggressive acceleration, and I would guess that 100% of this group is guilty of that. If you would like to see that happen, and your cable provider (I have Comcast) allows you to call up previous episodes of Bitchin Rides, go look at S1 Ep14 at around 28 minutes. The owner picks up his 69 Stang from Kindigit and there's a shot from the back as he pulls away under heavy acceleration...and gas comes out from around the cap.
Not sure I watch close enough to see a little seepage out the backside but I bet does. He is a creature of habit and all.Don't we all when there is a classic Mustang on the screen?!?
I suppose given your frustrations with fuel spillage you were specifically looking for it but still quite funny that anyone would catch it.
Since you quoted Craig about sparks and static in particular and then again referenced having the part zinc plated I have to ask. Is the zinc plating for more than just corrosion resistance? I can't see how the plating would have an affect on electrical phenomenon. Maybe I am missing something?tarified1 wrote: I honestly never worried at all about sparks or static.
No I didn't take your post as criticism, but thanks for your reply. Honestly I would feel much better about your design if you had it zinc plated, otherwise they are very similar.
I'm curious as to why the neck needs to conduct. The neck is insulated from the car via the hose and gasket short of the mounting screws. In most older cars I would guess the conductivity is not there.
do late model cars not create any static because the filler necks are plastic? gas tanks are plastic too on some
no I haven't. I did get asked to build one with a "check=valve" and I did. The guy who asked me to do it supplied the parts. It was a device marketed to the tri-five Chevy guys. I attached a few pics. He didn't like it so I made him one like the rest and he was happy. He gave me the one with the check valve for my trouble. I still have it.Craig I remember when you first started doing your modified filler. A quick question for you regarding your experiments. Did you ever try to remove the baffle/flapper from a newer tube and install it in a vintage tube? I have the filler from the '92 donor car and I have the original '66 filler. The tube diameters appear to be the same and I have toyed with the idea of removing the baffle/flapper from the '92 and then welding it into the '66. No sense in reinventing the wheel if you've already traveled this road!
