The blade is rotating the wrong way, that’s why the smoke is going away from you and the board is lifting. You should also use a splitter. That keeps the wood from binding and causing kickbacks.
As far as the fence, you can use it on either side of the blade. All depends on your dominant hand.
Mark
Mark
is extra sensitive to safety around saws as he came from an industry built around their use. Must have tucked them up under a headband or something to keep them from getting cut off.
