CUAviator
"I wanna go fast..."
Ah, someone put a serpentine system on it. Now it makes sense why you're stressing about mounting. What doesn't make sense is why you need something more than even a 100 amp alternator. The pulley diameter certainly doesn't look large enough to be under-driving it. All the stuff you list and the draw of all the stuff you didn't isn't going to draw anything that even a basic 65 amp alt wouldn't replenish. I'd make sure to clean up the wiring connections and the vehicle grounds. Then I'd do a test to see if there is a draw occurring when the car is off. Always a good idea to check this even when things seem to be good. Could be you just have a poor alternator and a new, better performing unit wouldn't hurt but don't waste your money on some super high output unit you don't need. My two cents, anyway.
Yep, you about had me going about why the heck you couldn't work something else in. Pictures worth a 1000 words there. Big old NOPE. You sir, I believe are going to keep rocking that Delco unit.
Are those GT40X heads? Sweet!
