66gt350
Stay away from the header wrap. It has a tendency to collect condensation while cooling and rot out the headers. Get a mini-starter.
"apollard" said:I'd check out db electrical. Lots of guys around here have used them for starters & alts, as well as a lot of my boating buddies. Never heard one bad things, high quality at great price. Wish I'd known about them before I got my used 3G alt.
http://www.dbelectrical.com/p-1321-new- ... d0001.aspx
"apollard" said:Large drop in idle is usually a lean idle setting. Normal is 150-250 rpm IME. Check the idle settings to make sure they are not too lean.
That's awfully low, especially for neutral."jmbour66" said:Okay, I'll play around with that. I'd like to get both the neutral idle and the in gear idle at about 600 rpm if possible.
"apollard" said:What Terry said - nuetral and drive will not be near the same for an older carbed car with an automatic - there will be a couple hundred difference. 600 in drive would be OK - assuming your engine is stock or a very mild build.
"apollard" said:With an E303 cam, you should be able to idle at 800-850, 650 or so in drive. That's not that radical a cam (and pretty much the same as the Lunatti in my build).
