Sluggo
Dig it.
"AzPete" said:Your skills could provide a very nice "card" for the wife......just need to land them in the right business. You have the design and build capabilities that are rare.
Outstanding.....
"Mach1ne" said:Keep it up and you are going to need that big diesel engine I just gave away to power the thing.
So you don't have to build your own starter button, I found one on-line for you.
"Sluggo" said:Dig it.
"67 Fastback" said::wor
Awesome skills man.
Bill
"silverblueBP" said:and to think, not only do I KNOW the guy, but he has my sweatshirt too.
"stangg" said:The bellcrank by design shouldn't be an issue since our regular brake pedals swing on an arc too... The belcrank, looks a little short thus not keeping the stroke more linear... I think one thing to try first is shorten the rod coming from the pedal, and lengthen the rod going to the M/C... If you have an even amount of travel on either side of center... then the stroke ratio will be more evenly split. The way it is now, the pedal to M/C ratio will increase... As you continue to press the pedal, you will incrementally have less M/C travel. It starts at 1:1 and ends at something like 1.25:1 (assumption on the actual ratio) ... I hope that makes sense.
If you could set it such that at the midpoint the bell crank arm is at a right angle to the M/C rod, then I think that would be the best geometry for what you currently have... Lengthening the lever arms on the bellcrank would help too...
"70_Fastback" said:That is exactly what I planned to do earlier when I mentioned re-adjusting the heims to reclock the bell crank! Scary huh...? :confu
"70_Fastback" said:I tried it that way, but believe it or not but it interfered with the tire on a hard left hand turn. It's close to rubbing as it is now. But it clears.
