Pretty sure we have a member here with the one-piece glass. Maybe he will chime in.
Jerry put them in his "Anti-Eleanor" 67 Fastback. He doesn't post here anymore but I could ask him for feedback if interested...Pretty sure we have a member here with the one-piece glass. Maybe he will chime in.
20171005_182402 by Brett, on Flickr
20171005_163352 by Brett, on Flickr
20171006_104028 by Brett, on Flickr
20171006_195416 by Brett, on Flickr
20171006_195430 by Brett, on Flickr
20171008_175106 by Brett, on Flickr
20171015_120445 by Brett, on Flickr
20171015_220935 by Brett, on Flickr
20171025_140458 by Brett, on Flickr
20171025_220046 by Brett, on FlickrDon't know if you made your power window decision yet so here is my 2 cents:
I installed the Electric Life kit along with one of the console switch kits from A-1 Electric about a dozen years ago.
Generally, the folks with slow "up" issues at that time had glass alignment problems which contributed to the issue. In my case I had emptied the door of all hardware prior to paint so I addressed the glass alignment as part of reassembly. Overall the Electric Life worked well for about 10 years. At that point the window motors seemed to labor in the "up" position. During troubleshooting I determined that the light duty switches seemed to be the limiting factor. Simply running power directly to the window motors confirmed the weak point. My solution was to fabricate a relay bank of 4 Bosch style relays. "Up" speed returned to acceptable.
In looking at the switch kits offered by Nu Life, they offer what appear to be some of the same switches as A1 Electric. I suggest a relay bank with whatever set you select.
I ended up installing a pair of console switches in the seat belt cups in the factory center console and covered the crank handles in the door panels with a pair of deluxe dash emblems for '67-'68. Some MacGyver-ing was needed but virtually everyone who commented thought the install was factory.
so let me understand, you are getting an Explorer 8.8 and will narrow it to use Fox 8.8 axles (at least the fox length axles because foxes were 4 lug)? Sounds cool
20171128_222649 by Brett, on Flickr
20171129_220108 by Brett, on Flickr
20171129_215820 by Brett, on FlickrThat's nice! Had to laugh at the last pic though as you must have been laying on the floor to get that shot!
