A
Anonymous
Guest
I'm not exactly following the rule book.
I'll get them posted up today for you."67 evil eleanor" said:Finally seen the vid. I'm not sure that's much slop at all. It seems that its fairly tight. Horseplay, I'd love to see pictures of the gear before you install it. I seen three other Troopers in the yard that are set to be crushed. I can buy the units for a few bucks each.
"67 evil eleanor" said:Have you tried to adjust it? It worked on this one. I know the power steering makes a little difference but the basic worm and gear have a clearance, and if you reduce this, then the slop has to go provided nothing else is worn out. If Borgeson agrees, then they should replace the unit until you receive a good one. In the mean time, you may to try to loosen the nut while holding the screw and then turn it in 1/2 a turn and tighten the nut once again as you hold the serew in place. If it works, then you should to remove all the slop, if it doesn't, I'm out of any ideas.
"bravenrace" said:Like I said (repeatedly, BTW :shrug), the box is bad. We know that. Adjusting it was the first thing I did, and didn't help. Its the second box I've had in it. It's a lot of work for me to swap it out, so I wasn't willing to just keep swapping bad boxes in and out while Borgeson let me do all the work for them. I finally got them to basically custom build one for me, and they say they are sure that this one is 100%.
