Mach1 Driver
Gypsy, who made the machine, model number, etc., or did I miss that someplace?OK. It's a (not cheap) little 13 inch belt sander. Different speeds and the belt can be rotated 360 degrees. It's pictured in the "fit in the frickin" drawer" position. It's a bit of an awkward shape. Body shop guys are big on these things and one of them turned me onto them. There's also an 18 belt sized one. You don't use it much but it's still handy as hell sometimes. Ever grind off a rivet or something with an angle grinder and leave "C" shaped grinding marks you wish you could have avoided? Everyone uses just the tip of these for spot sanding/grinding. Once you get in the habit actually having it around more uses for it seem to pop up. Like doing a super sharpen on a lawn mower blade without taking the blade off. Sometimes you will use it instead going to a big belt sander or bench grinder just bacause you don't want to walk over there. Spot weld grinding, taking shard edges off sheetmetal, all kinds of things you can do.
Belts in different grits can be had for a buck apiece or even less like off Temu or at Harbor Freight but the really good ones that last are made by 3M and run about 3 bucks each.
