Cool New Tool Thread
Grit my teeth and finally bought (on credit) this pricy little bastard. $1200.
Makes this mess more enjoyable to use, replacing a big "soap on a rope" corded thing.
I didn't even know Dewalt made this until I was about to buy a Harbor Froeght version. Super bright and it folds up, clips are spring loaded to fit different width hoods
I get so tired of buying new types of lighting only to find something better a few weeks later! I am still trying to find a really good spot type LED. The small magnetic ones you can sit next to an area where working. Either they aren't bright enough or the battery life is less than useable has been my experience. Any good suggestions?
I have a no-name Chinese one that has lasted me a long time and been through some abuse (look at the burns and pitting around the LEDs. The base is magnetic and the LED is on a gooseneck for precision lighting right where I need it. It takes three AAA batteries, and the battery life is so-so, but I keep some rechargeable AAA on the charger so I can hot swap them when it starts to get dim. A pilot friend brought it back from China for me, but I'll bet they're on Amazon, etc. It really helped when I was welding on a car frame, up on a lift, from underneath. Illuminated exactly what I needed to see.
I found one on Amazon that looks like a good replacement with a zoomable spot beam, under $20: LED Lamp
My hands down favorite of the last 10 years has been this little Saber 200. It isn't the brightest or longest lasting but I keep going back to it. The killer is it's magnet. It will hold it on a brake line, the tip of a bolt, almost anything. And you can aim it from there easily. https://www.bestbuyautoequipment.com/atd-80340b-saber-rchgbl-led-pocket-light-p/atd-80340b-02.htm
Downside is it's a little pricy for a pocket light. Also it's rechargeable so no batteries to hot swap. I feature I would not put up with with any other light. I have scads of rechargeable batteries at the ready for all kinds of stuff. But I'm on my third one anyway. First is stuck under a car somewhere. Second got crushed by hydraulics. Current one got mashed by a jack and no longer pivots after I glued it back together so I'm mulling buying #4.
I saw on HotRod.com a guy said Harbor Freight had one very close to it but at like half the price. I went to look but unfortunately HF found out people liked them and quit carrying them. At least that's what grocery stores seem to do about our favorite foods pretty regularly.
I still have the old 3T block and tackle but don't have the shed roof to use it now. This will do nicely.
Dunno how cool, but tools. I cracked a magnet in a Kawasaki stator using a homebrew puller. So after buying another stator I figured I ought to invest in a proper puller. After searching around I discovered I could buy a full set of Chinesium pullers for not a lot more than just the one. So..
Even considering I have a couple different bikes and grandsons do too, I still have to wonder if I will actually ever use any of them.
I don't let up I guess. Harbor Freight sale sucked me in again. Like $75 off and I've been wanting my own porta-power tools for a long time. Heavy sucker but it's got a pair of luggage wheels on the case. A plus. A minus is the fitting aren't quick connects, they're screw on. meaning you loose a bit of fluid every time you swap stuff around. When that pull hook thing goes on sale I want one of those to add to it.
Having broken the manual tire changer's bead breaker feature twice now I thought this thing might help. Also on sale until 01/30 for members. Haven't tried it yet and am still not at all sure about it. Seems heavy and solid though.
I just got a one of those long light sticks From BendPak:
The attachment for the hood above is too long for a Mustang hood, but the handles pivot and it has magnets in the ends to stick it under the hood or under the car- anywhere there is something with iron in it. The handle ends move and rotate independently of one another too.
Those things are great. Can I borrow it? Promise to give it back..
Well......if you want to cover the shipping....
And now this thing was "on sale".
A buddy let me use his 3/8" version a couple of times and I found it fits a niche. When you can't get at something with a pistol impact and an electric ratchet doesn't quite have enough torque. Like some fairly inaccessible bolt with LocTite on it that takes like a half hour to ratchet out.
Not a lot of power, as expected, but it's OK. I think I should have gotten the 3/8" drive version but I can live with 1/2" drive. Not a tool I expect to be used a whole lot anyway. Not sure if I would recommend this one. It works, but it's a pretty niche product. It does NOT work like a ratchet when unpowered. They make a smaller version of thos which has a skinny gooseneck where this one looks like a club. Do NOT buy one of those. They have about as much power as a kitten sneeze.
